Need Help With Stock Speakers 97 Trans Am
Hello everyone. I have a 97 trans am and im upgrading the speakers because the ones that are on the car are factory Delcos that are blown. I need advice on what kind of speakers to put in the rear panels right next to the backseats. I bought speakers from crutch field and was given a standard gm wiring harness. I then discovered that my car has the monsoon system and it's a special plug and those speakers only produce base. I want to try to keep the factory harness and not cut into it if possible. What speakers do you guys recommend I put in these panels? Thanks for any help.
You might want to check out the stereo and electronic forum there is a lot of info on this subject also you could always give Dennis at DoubleD Mods a call and he can set you up with exactly what you need.
dennis@doubledmods.com (608)568-3011
