BLS HID kit install on 02 camaro
So I recently received my kit from BLS, they look great and I am looking forward to using them. I have never installed anything like this before and don't know what I need to do (or how to do it). I did a search and found some threads that gave some good points to make the install easier, but I'm still a bit lost. The kit didn't come with instructions, so any help would be appreciated!
Copy & Paste Moderator
You got a complete housing right? Its pretty much a matter of unbolting the old headlights, bolt in the new ones, and adjust aim.
BLS is usually pretty helpful. If you contact him, he'll probably give you instructions.
Yes I did. Ok, well that doesn't seem so bad! He did mention something that I would need to do. Something like splicing two cables, it was an extra charge but I opted to do it myself. He mentioned I can find it here, you wouldn't happen to know what that is, would you?
He's probably referring to splicing into the high beam wires for the solenoid in the projectors for the bi-xenon hi/lo function.
There should be instructions provided. Ask him. Maybe they were missing from the shipment.
