Factory alarm question?
Old Jun 28, 2012 | 04:35 PM
Brewski4u1's Avatar
Default Factory alarm question?
in the last 2 days if i lock my doors the alarm goes off right away!! anyone have this happen to them? any fixes??
Thank You
-Ryan
Old Jun 28, 2012 | 10:42 PM
67goatman455's Avatar
search around. i guess the vibration sensor goes bad quite often. its in the spare tire well area. I read to just unhook it. might try it real fast
Old Jun 29, 2012 | 01:36 PM
Brewski4u1's Avatar
thanks i will give that a try
Old Jun 29, 2012 | 01:55 PM
Carguy8888's Avatar
Check if the car has a hood pin switch. I may have got out of whack.
Old Jul 2, 2012 | 07:30 AM
WhiteBird00's Avatar
Ungrounded Moderator
Factory alarms don't have a hood pin switch.
Old Jul 3, 2012 | 11:58 AM
LXinMS's Avatar
x2 on the unit in the spare tire well.
Mine likes to honk twice after the initial quick honks if it has rained a good bit.
Old Jul 18, 2012 | 06:36 PM
Fbody Barbie's Avatar
There is at least one other thread on this issue. My '99 Z does this too and it annoys the crap outta me because we just moved into a new neighbourhood and it's generally very quiet. I don't want to be that neighbour with the car alarm.
From what I have seen on this board, a bad shock sensor is likely to blame. Does anyone know how hard these things are to come by and if they're expensive?
Old Jul 18, 2012 | 06:48 PM
Carguy8888's Avatar
Cheap & under the dash. Set the alarm wait a minute & progressivly tap on the driver door glass and see how much pressure it takes to set it off.
Old Jul 18, 2012 | 08:17 PM
Uh, no again. The factory shock sensor is on the right rear wheel housing in front of the spare tire. It is part number 10444928 and costs $47 at the dealer and about $20 less online.
Old Jul 18, 2012 | 08:48 PM
I know where it's located...just wasn't sure dealers still had 'em. Thanks.
Old Jul 19, 2012 | 07:21 AM
Sorry, my comment was meant for the poster who first posted about a non-existent hood pin switch and then about the shock sensor being under the dash.
Old Jul 19, 2012 | 09:24 PM
Carguy8888's Avatar
Uh yes, i stand corrected. I was thinking of an aftermarket unit.
Old Jul 29, 2012 | 09:36 PM
Cleanupman's Avatar
Default Have the same problem
has anyone came up with a resolution? I have the factory alarm (want to stay OEM) and after the doors are closed i hit the alarm... 7 seconds later it goes off. I read the forum and reacted to the response that says replace the vibration sensor. While at the pull-a-part I pulled a sensor and installed it. I still have the same problem. One other note, I recently had to replace my batter because it was dead. Any suggestions... please help!
Old Jul 29, 2012 | 09:52 PM
OEM and factory are the same thing (OEM = Original Equipment Manufacturer). Try unplugging the shock sensor on the right quarter wheel well in front of the spare tire (there's a photo in the Monsoon FAQ sticky at the top of the section), leave it unplugged and see if the problem goes away. That is by far the most common cause of your symptoms.
