Problem Bypassing Monsoon '02 Camaro
I bypassed the amp for those rear speakers, so that they would be wired to be regular speakers, not subs.
by doing:
E4 + F14
E5 + F13
E6 + F16
E7 + F15
I spliced them correctly and plugged the harness back into the amp and had no sound whatsoever. If anyone can help me out here it would be greatly appreciated.
Thanks
There is no correct way to do what you are attempting. In theory, you would leave the four input wires (E4 through E7) connected to the amp and splice into them with the sail panel sub output wires (F4, F5, F10, F11). However, that won't work properly because you would be running only 2-ohms net to the head unit (two 4-ohm loads in parallel) and the factory head unit (as well as most aftermarket head units) is not 2-ohm stable. You risk burning up your head unit.
The best thing to do is ditch the coaxial speakers and get the correct 6.5" subs for the sail panels. Besides, you really shouldn't have full range speakers behind you except for rear fill and that's what the hatch speakers provide.
The other option is to disconnect the hatch speakers and use their full-range signal to power the sail panels.
So..
E1 + F6
F1 + F7
E2 + E16
E3 + E15
Along with the
E4 + F14
E5 + F13
E6 + F16
E7 + F15
that i did origionaly
Now I have front door sound and rear hatch. Nothing from the sails. So what would I have to do to get the sails working now?
Obviously, you didn't really read the other thread you posted in. Otherwise you would understand why it is not a good idea to bypass the Monsoon amp ("foolish" is the term used). You lose far more than you gain because you give up amplification (i.e. volume) for no good reason. You should not remove the amp unless you replace it with an aftermarket one because you're just running off the head unit and giving up power.
Now, I have the front speakers bypassed and they sound much better through just the HU I installed. The hatch speakers are working and I'm pretty sure they're still through the amp.
So my only thing left to get done is to get the sail subs working again. With the current wiring I did, I thought they bypassed the amp but I guess that's not the case as I have no sound from them. So, now that I will be bypassing the amp if necessary (although it is "foolish") for the sail speakers, what do I have to do? Im fine with having them stil act as subs. Just as long as I get some sound out of them.
If the door speakers don't sound right then switch the wire pairs because you probably have them connected to the tweeter wires (the doors came with components rather than coaxials from the factory). The wires for the door mids will give you full-range signal.
If you don't want to install subs in the sail panels then disconnect the hatch speakers and use their wiring to power your coaxials in the sail panels. You don't need four full-range speakers behind you.
The hatch speakers are not currently working through the amp - you bypassed them remember? (F13 through F16 are the hatch speaker connections)
Problem is now im confused. I thought I bypassed the front and the sail, but your saying I did the sail and the hatch. So ill take a look at the diagram and try to sort out what I did.
Man, I'm sorry but this is pretty basic electrical. Perhaps you should put down the wire cutters and have this fixed by a professional.
