new h.u, now alarm goes off...
well, i put in a new headunit last weekend... now i noticed when i lock the doors with the key fob, after a few seconds it sets off the alarm. ill hit the unlock button, the alarm shuts off, then when i relock with the remote, the alarm goes off after about ten seconds.... its really pissing me off what can i do to fix it?
Copy & Paste Moderator
It probably has nothing to do with the radio unless you have an aftermarket alarm that was somehow wired to the radio.
The culprit is most-likely the shock sensor on the passenger side rear wheel well. Remove the panel that hides the spare tire and you'll see a black plastic box about the size of a deck of cards sitting on the wheel well. Unplug it and see if the problem stops. If the problem stops, the shock sensor might be faulty or the wiring to it. Sometimes water gets inside it and causes problems.
Here is the image from my car in the Monsoon FAQ:
yea, that seems to work... ill just leave it alone then. thanks for the heads up!
i tried adjusting the sensitivity but it didnt do anything, but once unplugged, the problem went away
