Driver side speakers not sounding properly
Old Sep 23, 2012 | 01:13 PM
wgh234's Avatar
Default Driver side speakers not sounding properly
I have a 2002 T/A convertible, recently bought. I can turn the balance control to the left and turn up the volume to get a sound out of the driver’s side speakers from the radio and CD but nothing like the volume of the right speakers. I don’t know how to proceed to trouble shoot this problem. Let me say right off the bat that I am not technically versed in this sort of thing so if you could keep it simple. This affects both the front door and the rear speakers on the drivers side. Per the CarFax the car has had repairs to the driver window motor and seat belt re-tractor in the past.
Old Sep 24, 2012 | 10:06 PM
wgh234's Avatar
anyone
Old Sep 24, 2012 | 10:37 PM
badformulaLS1's Avatar
It is 10 years old. Speakers do tend to die out, or start farting after several years. Especially if the previous owner(s) liked to blast their music a lot. It may be due to something else though but like you I'm not technically versed in this stuff either so I wouldn't have a clue.
Old Sep 25, 2012 | 09:32 AM
PontiacFan's Avatar
keeaudio.com or crutchfield.com, or better yet, ..., the Audio forum on LS1Tech.
https://ls1tech.com/forums/stereo-electronics-19/
Old Sep 25, 2012 | 02:40 PM
wgh234's Avatar
Smile driver speakers not working
Thanks to you both. I will pull the door panel and use another speaker to see if it will work any better than what is installed.
Old Sep 26, 2012 | 07:22 PM
NitoV's Avatar
I had this same issue a bit ago, but for me it was the passenger side speakers. NONE were anywhere as loud as the other side. I swapped speakers, like you said you'd do, and confirmed that it wasn't the speakers.
Then i bypassed the Monsoon amp to ensure that it wasn't feeding the speakers bad signals and it wasn't the cause.
Turned out to be the HU, which I'm in the process of replacing.
Old Sep 26, 2012 | 10:36 PM
omgitsmikeyc's Avatar
You can take a double A battery, cut the speaker lines and test by placing positive to negative lines on those same spots on the battery. Then just crimp the lines back together. You should get a scratchy vinyl type sound, and if you do, then the problem is not the speakers. IMHO I think it's your amp, the channels are fried or dead, start with that battery test, if it passes, check the amp and then the head unit.
Old Sep 27, 2012 | 02:48 PM
wgh234's Avatar
Default Door speaker test
I pulled the door panel and tested the connection with another speaker and found no change in volume response.
I pulled the Head Unit and took a multi-meter and evaluated the volts being sent on the left rear speaker to that of the right rear speaker and there is a big difference with the right exceeding the left.
I even ran a wire from the HU to the speaker and gotten the same volume as the first test of a separate speaker.
Base on all this I am going to replace the Head Unit.
