99-up TA LS1 M6 and A4 Gauge Clusters the same?
Old 10-15-2012, 09:08 AM
mk3cn4's Avatar
Default 99-up TA LS1 M6 and A4 Gauge Clusters the same?
Searched, can't seem to find that specific answer, but according to this thread:
https://ls1tech.com/forums/3064671-post25.html
Firebird instrument cluster with lens (98 LS1) = 16232042
Firebird instrument cluster with lens (99-02 LS1) = ? (formerly 9380692)
...it implies that it's the same part number for A4 and M6. I know 98's are different, but when shopping for a 2002 LS1 M6 TA Gauge Cluster do I need to ensure it's M6 version, or A4 also works? Thanks.
Old 10-15-2012, 12:27 PM
eb110americana's Avatar
I'm guessing they should be the same as I have a '98 auto and when the sun hits it just right, I can see the SKIP SHIFT idiot light which isn't utilized on my car. One thing to watch out for though, is that I've heard lower spec models came with non-Z-rated tires and a speedometer that only goes to about 120 mph.
Old 10-15-2012, 01:33 PM
mk3cn4's Avatar
Originally Posted by eb110americana
...when the sun hits it just right, I can see the SKIP SHIFT idiot light...
That's an awesome clue, I bet you're right. Unless someone else chimes in I'll take the plunge. I want to tinker with whiteface/colored gauges and dont' want to take my car out of commission in the process, so am buying another cluster to fart with.
Old 10-15-2012, 09:31 PM
I've taken my gauge cluster out to replace a bulb and I left it out while driving to the parts store for the bulb. The weird thing about the configuration is that by the time I got home, the battery was dead. It's like the alternator wouldn't charge without the gauges plugged in.
Old 10-16-2012, 01:47 AM
Daniel Richards's Avatar
the only gauge difference I'm aware of is the V6 to V8 speedo difference aside from that, the lack of a "what gear your in" that most clusters have IE this (see attachment) from my old honda would suggest they use the same cluster.
Attached Thumbnails 99-up TA LS1 M6 and A4 Gauge Clusters the same?-100_0247.jpg
Old 10-16-2012, 04:48 PM
mk3cn4's Avatar
I'll take the plunge and if different I'll post here for future searchers.. thanks guys.
Old 10-16-2012, 05:54 PM
No problem. Good luck!
Quick Reply: 99-up TA LS1 M6 and A4 Gauge Clusters the same?
