'01 Trans Am Running lights / turn signals repaired
Old 12-16-2012 | 11:34 PM
RJDio's Avatar
Default '01 Trans Am Running lights / turn signals repaired
I know it has been mentioned many many times before, but WTH just did it and turned out good. old subject I know.
Front corner turn signals / parking lights were getting soaked! Took it apart and the plugs were barbequed.
Here are parts I used and steps for my '01 T/A
New 2 clear lenses $50.75 from Ebay
New 2 LED 3157 Amber lights $6.99 from Ebay
New 2 Sockets from AutoZone p/n. 85881 $7.99 each
New 1 blinker flasher from Autozone p/n. 552 $3.99
Lifted car on a ramp, only need to open side flaps (2 bolts each) under bumper. Strip wiring and soldered in new plugs, extended the wiring a few inches for future ease. Take care when reusing old screws, they will snap in the new lense housing, either pre-run in screws by tightening and loosening until in, or use a new shorter (and stronger) screw. I got them all wired and installed, lighted but didn't blink, a new blinker flasher fixed it (I think the soaked bulbs and wiring fried the blinker too).
Attached Thumbnails '01 Trans Am Running lights / turn signals repaired-lenses.jpg   '01 Trans Am Running lights / turn signals repaired-amberled.jpg   '01 Trans Am Running lights / turn signals repaired-plug.jpg
Old 12-17-2012 | 08:35 AM
WhiteBird00's Avatar
Ungrounded Moderator
You needed a new flasher because LED bulbs don't draw enough current to make the factory thermal flasher heat up and interrupt the current (flash).
Keep an eye on them - most LED bulbs are not warranted or capable of running as DRLs. They will fail because of the heat, usually in just a few weeks (couple of months at the most).
Old 12-19-2012 | 12:14 AM
RJDio's Avatar
thanks for info! I'll buy the led's by the pound then. I saw the electronic flasher at autozone for I think $9.00 and was tempted to buy it but wanted to try the $3.00 flasher first since I wasn't sure what was wrong.
Quick Reply: '01 Trans Am Running lights / turn signals repaired
