CDT Package from Kee Audio
Are hatch speakers even worth replacing with the CDT 4" ones or should I keep the stockers in there and only switch the door and sails with the CDT units?
I'm using the factory Monsoon amp
Rivets are only on the hatch speakers. You can remove the outer plastic assembly and bring it to your bench and drill them out. The aluminum is soft and the rivets come out off easily. You can replace the rivets with speed nuts and self tapping screws, probably included with your speakers.
The door speakers are mounted in a little plastic housing. You can take the whole housing out and also work with it on a bench. Again, soldering is ideal but optional. Butt connectors are always a viable alternative to soldering.
A buddy of mine said he would help, he said when he did the sound system in his Buick he just used a lighter and electrical tape as a solder alternative and he advised that I do it that way. Is that a common route to take?
Would you recommend switching out the stock hatch speakers for the CDT's or keep them as they are?
There is no real reason to replace the hatch speakers unless they are blown. They are for rear fill only so they don't need a lot of power handling capability. If they work and you don't want to drill them out then you can leave them and you'll never really notice the difference.
You should cut off the connectors from your factory door speakers and wire them to the replacement speakers. That way they will plug in to the factory wiring much like the harness adapter for the head unit.
