bixenon help please
Also, diodes are directional. Sounds like the diodes are backwards.
Also, since you did the high beam mod, remove the diodes since they are no longer needed.
The real problem is I guess after I activate the high beam the power seams to still run through keeping the solenoid down and the high beam active even if I deactivate the high beams from the handle
Last edited by WhiteBird00; Jan 15, 2013 at 07:27 AM. Reason: Merge consecutive posts
