Weird electrical problem? Radio & Windows Shut Off?
So on my 1998 SS everything is fine but every now and then out of the blue the radio shuts off and the windows stop working. It will come back on then back off several times slowly and then eventually come back to working. If you try to roll the window down immediately after the radio comes back on, the radio and windows shut off immediately again. Any idea what it could be? I really don't want to chase a short, maybe it could be a bad relay? Are these things on the same circuit?
Thanks,
Mike
Thanks,
Mike
Copy & Paste Moderator
BCM solder issue:
https://ls1tech.com/forums/stereo-el...der-issue.html
https://ls1tech.com/forums/stereo-el...lickering.html
Images appear to be missing from the first page of "The Fix" thread that Blu99T/A posted, but you can see a pic of the BCM and the affected solder points circled in the other thread above.
