Drivers side window
Old Feb 11, 2013 | 08:19 PM
CaptObvious's Avatar
when i first get in the car, my drivers side window will go down..but when i try to put it up, nothing happens, until i open the door and close it (for the most part) i figured maybe a window motor, but im pretty sure its electrical...where to start?
and i have replaced the switch....could it be the connections going to the switch have gone bad?
Last edited by WhiteBird00; Feb 12, 2013 at 07:09 AM. Reason: Merge consecutive posts
Old Feb 12, 2013 | 09:58 AM
wssix99's Avatar
Save the manuals!
Its most likely a bad motor. Opening and closing the door can knock the motor around or give it time to cool, which probably puts it in a space to work for a bit.
You should search the forum as there are thousands of posts on this. The motors are a consistent weak point on these cars and there are many good tips here on how to replace them and on which brands of motors will be most durable going forward.
Old Feb 12, 2013 | 06:16 PM
awesome, thanks alot! ill start there and see how it goes
Old Feb 18, 2013 | 07:41 PM
Blackpanther99's Avatar
You could also replace the wiring, seems to solve most of the problems with the windows or simply replace the motor.
Old Feb 18, 2013 | 07:57 PM
jbridwelltransam's Avatar
Grab a new motor from advance. Don't over tighten it, and put down correct info when they ask because they have a lifetime warranty.
