i dun messed up
Pulled in the garage and the passenger side was out, driver side worked. I went under to check the wires and when I grabbed them it came on. There was just electrical tape on. So i took the tape off and figured id fix it better with a wire nut and then tape it good.
That seemed to work. Light came on, signals work. I drove to work and then I noticed all my instrument lights were out. Tach, speedo, fuel, milage, battery was all out. Oil pressure still worked and stereo worked. Left turn signal light up inside, but right did not. All headlights and fog lights work.
Did I blow a fuse? Or did I cross some wires together that arent supposed to be?
Im at work right now so I will have to pull it in the garage later. Figured this is the best place to ask people.
