LT1 dash wiring issue
Posted other forums no one has been able to answer so i need your knowledge LS1tech. So here's my issue just did my engine motor swap engine was a stock 93 LT with the 4l60 swapped over to a built 93 LT1with a built T56 by tick. Engine and trans where installed everything was hooked up minus emissions a/c which was deleted on the chip by PCMFORLESS. Only wiring I've done to the car is electric water pump which I installed off the 20amp smog pump spot in the fuse block, I also wired the clutch switch in due to the swap cut shifter plug to clutch pedal switch. And I wired in three auto light gauges into my interior lamp circuit (wires for shifter illumination light) so at night they turn on when I turn my lights on. Other than that that's it and this Is the issue I have. When I turn the headlights on, the dash goes nuts when I turn the key on everything is normal (note I haven't started car since swap was installed waiting for slave cylinder before I do break in
http://http://i232.photobucket.com/a...11E5EA054A.mp4
