Interior lighting issue
Old Mar 30, 2013 | 01:32 PM
FormulaTA96's Avatar
Default Interior lighting issue
Was wondering if anyone could help me..My lights on my power lock/window buttons won't light up along with my gear selection column and the buttons on the steering wheel..My temp. and oil pressure on my gauge cluster will also not light up now..The only reason Im not sure if its just lights that are out is because one time while I was driving the gear column lit back up and my driver side lock/window buttons also lit up..But after turning the car off they never came back on..My power locks/windows work fine its just the lights..Are there any fuses I can check btw?? All help appreciated!
Old Mar 30, 2013 | 07:28 PM
Daniel Richards's Avatar
if it's the fuse causing those lights to be out then the whole gauge cluster backlight and your parking lights will be out too, the parking light fuse provides the power to all the interior lights that come on with the lights at night. If your exterior parking lights are fine then I would suggest checking your dimmer switch (if you have a friend with one try his).
Old Mar 30, 2013 | 08:09 PM
Yea my parking lights are fine,so i'll check the dimmer switch,thank you!
Old Mar 31, 2013 | 08:42 AM
wssix99's Avatar
Save the manuals!
Did you check all the common causes:
- Bulbs burned out.
- Door removed and bulbs not properly seated in the plastic trim piece that goes around the handle.
- Multi-directional LEDs installed that don't shine out the top.
- LED color other than red installed.
Old Mar 31, 2013 | 10:12 AM
WhiteBird00's Avatar
Ungrounded Moderator
... or the IP DIMMER fuse?
