Alternator question
Don't know how big your cam is, but unless the idle is extremely unstable the cam should have nothing to do with this.
I've also done the BIG 3 upgrade with 0 gauge which helped a little bit (I get a higher voltage at first when cold then before), from what I've read the next thing to try is to go around and clean all the contact points for all the grounds under the hood.
Is the fluctuation a constant pulse, or just an occasional dip and recovery? If the former, then it's probably the internal voltage regulator on it's way out, or some other internal alternator issue. If the latter, then it might be something as simple as the fans cutting on and off, which, depending on your tuning and cooling system, might be happening more frequently than would be normal for a stock car that has stock fan settings.
The cooling fans are about the only thing that would cycle on and off on their own and create a noticeable fluctuation on the volt meter at idle. Another less likely possibility would be an A/C compressor that is low on freon, and is cycling on and off while you have the AC/Defroster on....compressor clutch engagement/disengagement would cause a small voltage dip and recovery.
