Electrical tape to minimize resistance
http://www.summitracing.com/search/p...oil%20pressure
The proper fix depends on where the cut is. How far from the connector are the wires cut? Did they just pull out of the connector?
If you just need to splice the wires, you need a mechanical crimp, heat shrink connector to get a strong, reliable, water tight connection. Soldering is something to be avoided unless its combined with a mechanical crimp. (Due to the vibrations a car's wiring is exposed to.)
There is no room to take any length off of that wire.
Can you post a pic?
You may need to get a new pigtail to get the extra length and use a mechanical crimp clip or a good butt splice.
A solder splice makes the strands of the wire solid and this issue comes in to effect. So mechanical stabilization/reinforcement is required. GM's wiring repair kit has special (they work really well) mechanical crimps for splicing wires, which have a port to inject solder, but the tools to use them properly are expensive. The crimps above do the job well with regular crimpers and will also make the joint water tight.
Cars do have a lot of solder, but they are restrained (by a circuit board, etc.) so they aren't effected by vibration as much. The biggest issue is with a traditional solder splice which is unreinforced.
Most connections that the average user will encounter fall into the same category. For example, even if you were adding an under hood light, the soldered connection would not normally be in the portion of the harness that moves when the hood opens - it would be cable tied to some stationary point under the hood.
I have used soldered connections on motorcycles for more than 30 years without a single failure and I think you'll agree that a motorcycle generally produces more vibration than cars. I'm just careful to ensure the connection is well insulated, watertight and solidly positioned on a frame member or similar support.
I'd recommend a high reliability connection with this wire as its a real bitch to get to and securing it from movement/vibration would be hard. (Getting a soldering iron back there may not even be possible.) I've had to change my OPSU twice and never ever want to do it again. I can't even imagine trying to repair the connector wire with the engine in the car.
Personally I've had more crimp barrel connections wiggle or pull loose than soldered connections, but they were crimped with a cheap single tooth "mash" crimp as I like to call it.
