99 Trans Am headlights wont go up!!!
I went to turn on my lights and there was nothing. No grinding or sounds at all. Checked all fuses and they all looked good. Checked connections they looked good also. 20 min later i tried again and they came up? any idea what this is????
Save the manuals!
If you haven't previously removed it, you DO NOT want to start with checking the connector.
They all corrode initially - except for the small surface areas on the terminals that are in contact with each other. The corrosion in the connector problem usually starts the first time someone unplugs it and then plugs it back in. (Then the contacts are re-made over the corroded portions.)
So, checking for corrosion could give you the "corrosion problem," the the cause of your issue is something else.
Each side has its own connector. Its highly unlikely that the source of this issue is corrosion since its happening to both sides. Its probably something central, like a relay or a switch.
