95 6 speed Dash plugin
Old Oct 9, 2013 | 01:29 PM
RodneysPhoto's Avatar
Default 95 6 speed Dash plugin
I did a r and r on my 95 TA 6 speed dash and have 1 plugin that is hanging loose everything seems to work the plugin looks dirty and I redid some of the tape around the wires. for the life of me I don't know where is goes or if it goes anywhere. I have a 95 auto ta and it isn't on that car that I can see.
the plugin has a is grey + black with white stipe wires
Attached Thumbnails 95 6 speed Dash plugin-6d4a6800.jpg   95 6 speed Dash plugin-6d4a6802.jpg
Old Oct 9, 2013 | 07:34 PM
WhiteBird00's Avatar
Ungrounded Moderator
That doesn't look like a factory connector. Did the car have an aftermarket alarm at some time?
Old Oct 9, 2013 | 08:42 PM
It sure did, but I found the connector on the ac delco site so it made me think it was a factory plugin needing to go somewhere its a PT1769 plug u can find it 3/4 down http://www.acdelcotechconnect.com/pi...cavity/female/
Last edited by RodneysPhoto; Oct 9, 2013 at 08:44 PM. Reason: forgot to put in the link
Old Oct 10, 2013 | 01:45 AM
Spartan7's Avatar
That looks like the connector for the cruise cancel adapter harness.
Old Oct 10, 2013 | 07:20 AM
It's not the connecter itself that makes me think "non-factory" - it's the wire colors. Black with white wires are very uncommon in the factory harness but are used extensively in aftermarket accessories.
The 2-pin connector does look very much like the cruise cancel switch connector or even the brake switch connector but the wire colors are wrong.
Old Oct 10, 2013 | 09:41 AM
thx for the reply's. the cruise cancel is already hooked up it has a y cable conn's that go to the brake and clutch then hook into a black conn with a center bump out
Last edited by RodneysPhoto; Oct 12, 2013 at 07:29 PM. Reason: changed hood to hook
