My custom amp rack & amp installation (lots of pics)
power wire comes off the BATTERY and goes thru the rubber grommet in the firewall hidden behind the PCM, once inside just run it under the carpet to the amp location, RCA's simply go from the headunit to the amp under the carpet as far away from the power wire as feasible (minimum 18 inches) and if you are forced to cross the RCA's over the power do so at a 90 degree angle.
There is a groment behind the PCM that you can pass your power wire through then run it under the carpet along the passenger side. Your RCAs should be run a minimum of 18" from the power wire. I ran mine down the center of the car which required removing the seats, center console, and carpet. It did sound dampening so all that stuff was already out anyways.
Make sure to have a torx bit for the seat belt bolt. It's SO much easier with that out of the way. I put my RCA cables down the driver's side. Across the back of the car, I kept the RCA cables high, and the power cables low. Sorry I didn't include any pictures of routing the wires along the sides of the car.
