Alternator Test
I'm having issues with voltage bouncing up and down from 12 to around 15/16 and my AutoMeter fuel and nitrous pressure gauges are not giving accurate readings (bouncing all over the place.....the N2O gauge shows pressure on the line even when the bottle isn't in the car and the N2O line is disconnected).
Based on my research, it seems this indicates there's an issue with the voltage regulator inside of the alternator. The question I couldn't find an answer to is if there's a way to test this (or if this in itself is enough information to just go replace the alternator). I gather most machines that test the alternator will test if they don't provide a sufficient charge and given these symptoms it seems it might not recognize the problem (mine is charging, however it's not properly regulated). Any advice on the next step?
Definitely having the dimming light issues. With the car idling at a normal level, I'm still getting 14-15 volt readings with the lights, stock radio, heater and rear defrost on and the car has a 25% underdrive pulley. Just seems odd to me that it would read this high when before this issue it would read in the 12-13 range with all of the accessories on.
Is that in itself enough to signal that it's time to replace the alternator?
Still, diagnostic testing is always the best way to prevent randomly changing parts searching for a solution. If you have a voltmeter (or multimeter), it will only take a few minutes to test if the voltage is varying significantly.
I'll get my voltmeter and give the test you noted above to look for fluctuations in voltage at the battery. Forgive my ignorance, however I'm guessing it's as simple as positive-to-positive and negative-to-negative between the battery terminals and the voltmeter while the engine is running....and if the readings are floating up and down between 12-15 volts wildly, it confirms there's an issue with the regulator within the alternator.
IMO - watching the gauge fluctuate wildly is pretty reliable and accomplishes the same thing as above. It's essentially just a small voltmeter in itself.
EDIT: Looks like the "DCV 50" setting on this one should do the trick. I'll check this out tonight after work.
Battery voltage: cold, car off was between 12.05 - 12.20 volts
The reading on the voltmeter when connecting to the battery with the car idling, lights, AC, defrost, radio, (all accessories on) ranged from 15.10 - 15.50 volts. It would occasionally bounce a bit but not wildly like I expected it would.
Doesn't 15.10+ volts at idle with all of the accessories drawing power seem really high? Car also has a 25% UDP. If I'm interpreting this data correctly, the alternator is charging however it seems the voltage regulator is not working to keep it within the ideal range.
Here are a few of my notes from the install:
1. The "truck" alternator lined up well with the mounting bracket and bolted in without issue.
2. Since the plug for the exciter wire is rotated a bit from the stock 105 amp alternator, I only have about a half inch of "play" left in that wire.....if it were rotated any further down it would require extending the line.
3. I have a 25% underdrive pulley and was running a 75.5" (inside diameter) belt -- Gatorback P/N 4060755 before the install. That belt was a snug fit. The pulley on the truck alternator is the same size as the stock alternator pulley, however the location when mounted is shifted ever so slightly outward, so it took a 76.0" belt.
4. Once I started the car up, my crazy charging issues seem to be solved. No more flickering lights, no more bouncing voltage needle. The needle hangs in the 13.0 - 14.0 range consistently. Problem solved.
also the 4 screws that go "across the black area" connecting the front and rear of the alternator case can be undone and with a little force you can seperate the 2 halfs and rotate it around so the exiter plug and positive lug out to battery sit in a different location, just make sure you reseat the brushes in the alt if you pull it to far apart, again the videos on youtube of reassembling one will explain that better.
AlternatorMan on youtube is awesome. At one point I was considering replacement of the broken voltage regulator in the first AD244 I picked up.....my wife really enjoyed sitting on the couch listening to about an hour of the videos one night! Haha!
