Need help with 8" Kicker Comp
Old May 10, 2004 | 11:02 PM
Bigvic's Avatar
Default Need help with 8" Kicker Comp
I had two 8" Kickers laying in my garage for about 5yrs from a previous system. About two months ago I built a stealth box on the driver's sided and added one of them to my monsoon system for a little extra bass. It doesn't rattle your teeth out, but I think it complimented the stock monsoon pretty good. It was perfect for my taste. Anyways I noticed that it hasn't been sounding as good as it did when I installed it. After inspecting it, I noticed that all the squishy material that attaches the cone to the frame is torn all to hell. I am assuming that it dryrotted from sitting, and after running it pretty hard in a sealed box, it blew it to pieces.
I realize if I stick the other one in there, it will probably do the same thing. I was just wondering if there is anything I can do to postpone the inevitable. I am thinking that a thin layer of silicone around the undamaged one might keep that material from ripping. Should I do that or is there a compound that is made for repairing/reinforcing this stuff.
Thanks in advance.
Old May 10, 2004 | 11:49 PM
sercastiK's Avatar
those speakers new are cheap on e bay if the other one does blow....if you must have that one u can redo the surround
