dash illumination wire
Old Feb 5, 2014 | 01:17 PM
vetteklr23's Avatar
Default dash illumination wire
Does anyone know which color wire is the dash illumination wire? I am installing three autometer gauges and just want to make sure I wire them up correctly.
Old Feb 5, 2014 | 10:11 PM
Mista Blazer's Avatar
if im not mistaken i do believe its an orange wire
Old Feb 6, 2014 | 12:01 AM
vetteklr23's Avatar
I was thinking that it was the orange wire, just wanted some verification. Thanks for the help!
Old Feb 6, 2014 | 01:05 AM
I have been known to be wrong. But I'm pretty sure its the same for the radio.
Old Feb 6, 2014 | 07:32 AM
WhiteBird00's Avatar
Ungrounded Moderator
No. The use of the orange wire (or orange/white wire) is specific to the harness adapter used to connect aftermarket head units to the factory wiring. It has nothing to do with the factory illumination wires in the dash. In fact, orange is generally used by GM for battery constant power.
Depending on whether you want simple on/off power with the lights or you want variable power to dim with the instrument cluster, you will use brown (on/off) or grey (dimmer) wires from the factory wiring. Both colors are used for other functions in some areas so always check with a test light or multimeter or make sure you locate the wire where you're sure it is connected to lighting (e.g. back of the headlight switch).
Old Feb 7, 2014 | 02:48 AM
vetteklr23's Avatar
You are correct WhiteBird00, don't ask me how I found out that the orange wire was constant power hahaha. Thanks for the info, it is a tremendous help!
Old Feb 7, 2014 | 06:53 PM
vetteklr23's Avatar
So, I got all three gauges wired up, started her up and after a minute or so, I lost illumination in one of the gauges. I only lost illumination as the voltmeter gauge still works. I am thinking that I overloaded the circuit and it is drawing too many amps for that third gauge. I hooked up all three to the brown wire on the parking lights. Anyone have suggestions on how to get the illumination back? All fuses are good, all grounds are good. I can't be rolling around with two of three gauges that light up hahaha!! I mean it, I really can't, someone give me a suggestion, please!
Old Feb 7, 2014 | 07:08 PM
I doubt your diagnosis is correct. If all three gauges have their illumination wired to the same parking light wire, it is not possible that two would work and the third wouldn't because of too much current draw. An overload would either blow a fuse or cause all of the lights on that circuit to dim depending on whether you wired in parallel or series.
Since only one light is affected, you should check the things that are unique to that light. Check both the power and ground wires for loose or broken connections. Check that the bulb hasn't burned out - you can swap a bulb from one of the other gauges to test that.
Old Feb 7, 2014 | 07:20 PM
vetteklr23's Avatar
I have checked those things with that one gauge and everything is good. It does have illumination when I hooked it into the grey wire but it is much dimmer and yes, the dim is all the way up and it just is not as bright. When I turn the parking lights on, the illumination quickly comes on and then off so not really sure now as far as what to do.......
Old Feb 7, 2014 | 07:41 PM
vetteklr23's Avatar
Can I tap into the fog lights?
Old Feb 8, 2014 | 08:21 AM
It wouldn't matter - all the parking/running lights and fog lights are on the same circuit so the available power is the same whether it's going to a side marker light, the tail lights or the fog lights.
The problem is with that one gauge not the power source.
Old Feb 13, 2014 | 02:21 AM
vetteklr23's Avatar
I went ahead and reworked all the wiring and guess what? They all work now, it looks awesome. Thanks for the help WhiteBird00!!
