Trans am retractable Antenna Question
When i power up/power down the radio the antenna does not move and the gear/motor does not run but it clicks. Almost sounds like a solenoid clicking on and off? Does anyone has a suggestion or remedy for this? thank you
The power antenna has two power sources - battery (constant) power through the RADIO ACCY fuse to actually power the antenna motor and a 12V signal from the radio that controls when to raise and lower. You know the radio is working so the constant power supply is the other possible cause.
If the former, then there are some things you can try. If the later - see post #2.
GM has been aware of the gumming issue and has a service procedure to rub the mast down with a rag and mineral spirits until the mast operates smoothly. The paint sheds off the mast (not uncommon after a winter of driving on salted roads) and gums up the sections.
This happened to me several times before I shaved off my antenna and adopted WhiteBird's hidden antenna mod. Once the mast starts gumming up, it requires regular cleaning, but it usually got the thing working for me. Two times, I had to replace the mast. (It's available as a part separate from the motor.)
If you could do what you did, then the internal strip or something else is broken. (You should not be able to pull the antenna up if the gear was engaged properly.)
You might be able to get the mast out, but odds are that you have broken pieces of the old rack wrapped around the gear, which are very difficult/impossible to get out.
