adapter plug from monsoon amp to aftermarket
![](http://i59.tinypic.com/egodoo.jpg)
Here cut off the plug like i did and you can splice them into a 4 channel am I couldnt tell you whats what since its been along time but these will bypass the monsoon amp once you figure out whats what splice and a new amp in
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
ok well no one makes it so i will and heres my start i dont want to be limited as to what i can use and i dont want to gut my car to do it either so here gos i have a diagram of the amp wires and all i need is the output to the speakers from the amp since i will be running rca's for a cleaner signal. an amp and remote wire. which the diagram shows there is a remote there and is labeled as such.
ok i found my amps not to big but just right they are the clarion xc1410 which are 2 ohm stable so i can run the same all the way around and maximize my power or just stay four ohms. plus they have high low filter pass so i can run mids and tweets separately , also they are compact and i can mount them where the monsoon amp was and still have room for a mono block later down the road.
