Factory alarm only chirps once upon arming?
Just today, my alarm started chirping only once when I arm it. It's always chirped twice before. The lights still flash once and the LED in the dash blinks every couple seconds. That seems normal. Could a shock sensor be going bad?
Beautiful, I went out and checked the doors and hatch. None of them appeared to be open. I opened and closed all of them though and that did the trick. Thanks!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Originally Posted by Jake99SS
Beautiful, I went out and checked the doors and hatch. None of them appeared to be open. I opened and closed all of them though and that did the trick. Thanks! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Copy & Paste Moderator
http://www.blackcamaro.com/trunklid.htm
I replaced my spring with a stronger one. It opens easily now, but its harder to close. Sometimes I have to re-pop it and try again. An easy way to tell if the hatch if not fully closed is that the gap between the hatch and taillights looks unusually large.
