Any easy fix for terrible door speaker sound (no mids)?
Maybe it's an inherent design flaw in the doors, but i just can't get good mids out of them, particularly midbass. I have the midrange boosted by 2dB (aftermarket head unit), and it's still anemic, with virtually no midbass. I have tried several different sets of speakers, my most recent set being a pair of Alpine SWE coaxials modified to use the stock, separate mid/tweeter wiring. On my various camaro's I have tried everything from modeling clay filling all the gaps around the plastic speaker mount, to rope caulk/closed-cell weatherstripping. Does anyone on the forum make wood door inserts to replace the air-leak prone factory speaker mount? Would they even make a difference?
I have the monsoon system, but I've noticed the same problem in a 96 Z28, and I remember even back in the day when I had my almost new 94 Z28 (/w horrid bose system), it was the same way. A friend has an LS1 T/A with factory components/door panel pods, and the difference is night and day. I was thinking about swapping a set of T/A door panels, but I've read about it being a PITA, and I don't believe the color will match exactly. I thought about Q-Forms, but that looks like too much work to sacrifice so much leg room.
When the mids on a factory set of 5 1/4's in a freaking Toyota Yaris, or Chevy Sonic (delivery cars driven for work) sound amazing compared to the 6.5's in my camaro, something is seriously wrong
Any suggestions that won't require a carpentry or engineering degree to accomplish?
Are your doors sound deadened? Do you have a high pass filter set? (As mentioned by danielrichards). Also, coaxial speakers in general aren't goin to give solid midbass. Also are you on the factory amp or aftermarket?
