ABS/ TCS delete. complete wire removal?
Old Sep 7, 2014 | 06:50 PM
Baynut's Avatar
Default ABS/ TCS delete. complete wire removal?
I'm cleaning up the engine bay while doing my ls3 and 411 swap. Would it be possible to remove all of the wires from these components and not run into any problems. I have to remove all of the harness anyway to smooth and paint then wire tuck. Any advice would be awesome.
Old Sep 10, 2014 | 06:51 PM
Baynut's Avatar
Nothing?
Old Sep 12, 2014 | 09:13 AM
high n dry's Avatar
Im in on this as well...
Old Sep 12, 2014 | 09:50 AM
high impact's Avatar
Sure it can be done if you have the harness removed. Will you run into issues? Depends on how particular and thorough you are. Print out schematics, mark all the connectors so you know what you are dealing with and eliminate just what you need to eliminate. It's a big job and not for the faint of heart or electrical novice. I eliminated no longer needed wires a few feet into the harness when I did my wire tuck for now but plan to do even more wiring clean up during the winter.
Old Sep 12, 2014 | 12:37 PM
TechCam97's Avatar
I just moved my unit when I cleaned up my wiring:
Now I don't have to see it, but I also don't have to worry about any electrical nightmares by cutting it all out of my wiring harness.
Old Sep 12, 2014 | 01:05 PM
Blownbayou's Avatar
Moved mine also along with some other little things done.....
