front turn signal lamps
hey guys I don't know if this is normal or not, but for the 4th gen trans ams the 1999 specifically, is it normal for the front turn signal lights to be on solid as if the parking lamp switch was on?
Actually no... you'll notice the brightness change either way.
With the key on, turning on the headlights makes the lights go from bright (DRL) to dim (parking/running lights).
With the key off, turning on the headlights makes the lights go from dark (off) to dim - still a change in brightness.
