Replacing dimmer switch
Old Nov 6, 2014 | 06:52 PM
KingJacobo's Avatar
Default Replacing dimmer switch
My dash lights won't stay on. The dimmer switch has been on and off since I got my car, usually if I hit the switch or top of the dash it will eventually come back on. Lately it's gotten to the point that it will flicker but won't even stay on after I hit the switch.
What tools do I need to remove the he switch to inspect and possibly replace? I know I need at least a 7mm
Old Nov 7, 2014 | 07:12 AM
WhiteBird00's Avatar
Ungrounded Moderator
No, you don't even need a 7mm socket. Removing the headlight switch (including the dimmer dial) is just two steps...
Pull off the instrument cluster bezel:
Snap the headlight switch out of the dash:
1 = headlight switch connector
2 = headlight/dimmer switch assembly
3 = dimmer switch connector
Old Nov 7, 2014 | 10:48 AM
KingJacobo's Avatar
Wow thanks so much for that easy walkthrough!
Any way to tell if the dimmer switch failed or other parts without just replacing one part at a time?
Old Nov 7, 2014 | 03:25 PM
JOHNNY59's Avatar
you check the dimmer switch resistance with a multi-meter. if you need any help just PM me.
