NHRA complient rear battery relocation?
also, the Kill switch must kill the 12v side, not the ground side
if you are worried about your alarm... just make sure you wire power and ground for it Directly to the battery and not to the dead side of the kill switch.
Do the rules say the switch has to be permanently mounted? I was wondering if you could build some sort of mounting bracket that would allow the switch to be tucked away inside the car when not at an event but be remounted to be outside accessible during an event. Perhaps something similar to a trunk-lip mount that clamps to a body panel when needed?
A fancier option that would involve some body work but be quite unique... what if you put the equivalent of a gas filler with a removable, locking (or remote release) door on the right side? It would look like an ordinary gas filler door except that it would have the kill switch under it. With either a key lock or remote release it would be secure against tampering on the street. Then the door could be opened and removed at an event leaving an easily accessible (although recessed) kill switch. Since your battery will be in the right rear quarter panel, the switch and door would be conveniently close to the connections. If done well, I doubt many people would even notice that you have two "gas filler" doors.
