Will this alternator work?
Old Mar 18, 2015 | 09:16 PM
dthomas1234's Avatar
Default Will this alternator work?
I have a 2000 Trans Am. This alternator is from my old suburban. It is a 300amp excessive amperage. It has the right connector. The suburban had 1 wire going to it.
Old Mar 18, 2015 | 09:32 PM
RedDeadG8's Avatar
does the casing say AD244?
Old Mar 18, 2015 | 10:40 PM
Daniel Richards's Avatar
what year suburban?
Old Mar 18, 2015 | 10:58 PM
I believe it is an ad244.. i will go check later to verify.
Old Mar 18, 2015 | 11:00 PM
Originally Posted by Daniel Richards
what year suburban?
It was a 1996, but i think it originally had a different style alternator on it.
Old Mar 19, 2015 | 10:07 AM
get us a pic of the side profile of the alternator on the AD244's the front and back casings are separated by a black piece that is part of the stator, where the earlier generation alts like what came factory on these cars, the CS130D, have the front and rear casings of the alt touching.
Old Mar 19, 2015 | 03:16 PM
I will grab a picture when I get home, but it does have the black seperation between the casings.
Old Mar 19, 2015 | 08:29 PM
Here is a side pic.
Old Mar 19, 2015 | 09:51 PM
sure looks like an AD244, should work. you'll only be able to use 2 mounting points, the 4-prong plug is the same plug, since it's a high power alt I would suggest also doing the "big 3" wire upgrade with 1/0 wire. there are several threads on swapping to an AD244 alt with the LS1 on here.
Old Mar 19, 2015 | 10:44 PM
Thanks. I had searched the forums and was pretty sure it would fit, but wanted a 2nd opinion. Yeah big 3 is a must. Also adding a 2nd battery. My sub amp is 3k rms. Have to have stout electrical.
