Couple stereo questions
Old Mar 27, 2015 | 01:37 PM
Tranz Zam's Avatar
Default Couple stereo questions
The stock Monsoon system in my T/A has had it. I've put it off long enough.
Right now the car still has its complete stock system from 2000, and after 158k miles it sound like its under water playing through a tin can
I have one of those cheaper Pioneer setups that Walmart sells, I had it in my truck before I sold it. It has the head unit, two 6x9's and two 6.5's. Is it worth it to install the head unit and the two 6.5's in the door, and buy the two Bazooka 6.5" subs for the sail panel while running it through the stock Monsoon amp? I know the stock Monsoon setup runs at 2ohms and the stuff I'd be putting in is 4ohm.
Or...
Would I be better off replacing the blown speakers with new ones while keeping the stock head unit? I'd really like to use my ipod in the car, but if the Pioneer setup is going to cause issues I can take the trade off.
I didn't want this to turn into a big ordeal, but we all know how that goes.
Old Mar 27, 2015 | 04:56 PM
WhiteBird00's Avatar
Ungrounded Moderator
In general, replacing the factory head unit will give you a large improvement in sound quality. That's assuming you have the correct, functional speakers. The Bazookas work well in the sail panels but your plans for the doors are problematic. I suggest you read the Monsoon FAQ sticky first and then look at possibly putting the correct component speakers in the doors. In the long run you'll like it better.
Old Mar 27, 2015 | 05:40 PM
KEE AUDIO's Avatar
Hey, I have exactly what you need for that car.
If you want to do the bazookas and a radio I have them and include your install gear for the radio in addition to using top notch gear. The radios I use all have bluetooth and other stuff to bring your car up to date and have much improved sound.
I also have correct speaker packages that are specifically for your car vs. 4ohm Walmart speakers. If your going to upgrade your system, might as well do it right. Putting 4ohm Walmart Pioneer speakers in your car isn't a great start....just sayin.
Old Mar 27, 2015 | 08:12 PM
Tranz Zam's Avatar
Yeah that's what I figured. I have them laying around, and anything is better then blown out stockers, but I don't want to do this twice. I'll look into the packages Kee Audio is offering.
I have an older Kenwood amp that powered two 12's. Could I use this as a replacement for the stock monsoon amp?
Old Mar 27, 2015 | 10:05 PM
Daniel Richards's Avatar
an amp for powering 2-12's is NOTHING like what the monsoon amp does, the monsoon amp powers ALL the speakers in the car (except the front tweeters on some, I forget which one), you would not use a sub amp to replace it.
Old Mar 28, 2015 | 10:51 AM
Tranz Zam's Avatar
Ok cool.
As you can tell I build engines, not sound systems
