Which 6.5 is better?
CDT Audio HD-65NX HD Series Slim 6.5" 2-way Coaxial Speaker or
Polk db651
Thank you.
The base factory system has four full-range speakers located in the doors and sail panels. The door speakers are 4-ohm while the sail panel speakers are 10-ohm. That difference restricts power to the rear speakers so that they become rear fill rather than a primary sound source. It's not an ideal solution but it works okay especially if you like the "surround" sound experience.
10-ohm speakers are very uncommon and almost impossible to find in the aftermarket but you can accomplish the same effect by careful use of the fader control on the head unit. Another option would be to install 8-ohm speakers in the sail panels but I think the fader option is much simpler.
Still, it wouldn't hurt to get something other than coaxial speakers for the sail panel. The added high frequency reproduction of the tweeter will only serve to emphasize the fact that the sound is coming from behind (higher frequencies are more directional than lower frequencies).
To answer your specific question, the CDT is the better speaker overall but much more expensive. The Polk would be more than sufficient for the power you plan to use.
FYI, convertibles don't have sail panels. The term "sail panel" refers to the way the large pillar behind the doors resembles a sail. Without the "sail", the panel is just called a quarter panel.
