Pillars, Gauges, and Parts; Oh My
I've done my searching, and read the posts, but I'm still stuck. I really like the look of Dakota Digital but the cost Cyberdyne is very good. But since a pillar only comes for 3 gauges, no matter which brand I eventually go with, I'm having a hard time deciding about which gauges:
Oil Temp
Oil Pressure
Water Temp
Fuel Pressure
Trans Temp
Air/Fuel
Dakota is $79.99 for each gauge except for Air/Fuel, and the Cyberdyne is $49.99 for each except for the Air/Fuel. Then as I've learned from reading around here, some Air/Fuel aren't even that accurate, maybe even more so after you delete 02 sims after Long Tube Header install and tuning afterwards.
Car is a daily driver, but luckliy not so much anymore thanks to a new affordable lease on a '04 Nissan Frontier Crew Cab w/ Long Bed (for parts and furniture etc).
I guess it's still comes down to: what am I going to be doing with and to the car, ie daily driver, track, street, etc. For right now, I'm thinking that air/fuel isn't going to be needed because of long tube header install and the eventual tuning that the car will need with all the new parts (FLP LTs, , Dual Electric cutouts, 3800 Converter w/ TransGO and B&M Cooler, MTI Lid, Desceened/Ported OR Z06 MAF calibrated for F-body, Ported TB, HP Tuners). Yes, no, good, bad, let me know, thanks
Oil Temp
Oil Pressure
Water Temp
Fuel Pressure
Trans Temp
Air/Fuel
Oil Temp
Oil Pressure
Water Temp
Fuel Pressure
Trans Temp
Air/Fuel
Oil Temp
Oil Pressure
Water Temp
Fuel Pressure
Trans Temp
Air/Fuel
STF Veteran
Check out the Nordskog guages in the Summit catalog. Here's a direct link to their site. http://www.intellitronix.com/
At the moment, I'm leaning towards:
Oil Pressure
Fuel Pressure
Trans Temp
Although, the shop I'm getting installed at, refuses to do Trans temp
THe best combo, in my opinion, would be oil temp, trans temp, and oil pressure. Fuel pressure should always be a mechanical gauge mounted outside the car, in my opinion.
