Interior lights wont turn off
You can test the door and hatch switches with a multimeter using either the continuity setting or the DC resistance (ohms) setting. Unplug the blue 32-pin connector from the BCM. Find the three wires in positions D11, D12 and D13. They are gray/black, black/white and orange/black in that order with an empty pin preceding and a light green wire following. Connect one meter probe to a good ground such as a dash bolt and touch the other probe to each of the pins in turn. The meter should indicate continuity to ground (or 0 ohms) when the corresponding door is open and no continuity (infinite ohms) when the door is closed.
D11 - gray/black - driver's door
D12 - black/white - passenger's door
D13 - orange/black - hatch
