Wiring Hella Micro DE Fogs
Here are a few diagrams and pic of the wire
Last edited by WhiteBird00; Jan 10, 2016 at 08:18 AM. Reason: Merge consecutive posts
Would it be easier to cut the hella wires and buy a oem connector that way I do not cut into the factory connector? Do you know what type of connector I would need?
There is no factory connector on the lamp side for the harness because the factory harness plugs directly into the bulb rather than into another piece of harness. You can buy a part called a "harness extension" that has a male plug and female socket connected by a short pair of wires so that you can cut the male plug off to attach to your Hella lamps. It will then plug into the female socket on the factory harness. What you're looking for is an "H11 extension harness" because H11 halogen bulbs use the same connector as the 881/894 bulbs used in the factory fog lights. They are available from Amazon for under $8 a pair.
