Battery relocation
Old Jan 18, 2016 | 05:40 AM
mngoos's Avatar
Default Battery relocation
So I have a 99 camaro and want to move the battery.There is a lot of info but gets really confusing. I am not good with electrical work either so here is a few questions I am trying to figure out.
Do I need a fuse or breaker?
Where did u vent it at?
Where did u ground it at ?
Is there a way to hide or remove the battery disconnect switch (I don't like how it looksd this is my daily driver) but want to be up to nhra rules?
And is there a cheap box and mounting kit ?
Will the stock battery work for now?
Thank you
Old Jan 18, 2016 | 06:40 AM
OVRKILL's Avatar
Tick has a nice "idiot proof" set up. Everything you need except a box....they use a BMR tray. Stock battery works fine....
Old Jan 18, 2016 | 11:08 AM
blackbyrd's Avatar
might be of some help
https://ls1tech.com/forums/stereo-el...-tutorial.html
Old Jan 18, 2016 | 07:41 PM
RobsZ28's Avatar
No, just the disconnect switch
Mine vented out the bottom of the car, right next to the box
I ground mine to the bolt that hold the nitrous bottle mounting plate to the car.
No, not really if you want to be NHRA legal. Per NHRA rule the cutoff lever needs to be on outside at rear of the car and clearly marked for on/off position.
I bought a Moroso battery box from Summit, I think it was $55
A stock side post battery will work with a battery tray, but not with a box. Battery fit pretty tight in a box, not enough room for cables and side bolts. Also a rear firewall is needed if the battery is in a tray, you don't need the firewall with a battery box.
Thank you
I agree with OVRKILL, I just used the kit from Tick Performance on my car. It is pretty idiot proof, the directions are great.
Old Jan 18, 2016 | 09:01 PM
EarlyZ28!'s Avatar
This is something I need to look into coin soon... Have plenty of weight reduction... Need more transfer
Old Jan 19, 2016 | 08:55 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Anytime we have anybody looking for a complete battery relocation kit we send them to Tick Performance as they have a nice kit that utilizes our BMR battery relocation box.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 20, 2016 | 12:56 PM
Sales@Tick's Avatar
Here is a link to our relocation kit.
http://www.tickperformance.com/tick-...or-ls1-f-body/
