3157 or 3157CK????
Old Mar 2, 2016 | 08:42 PM
Fier23's Avatar
Question 3157 or 3157CK????
Are the tail light sockets on my 2000 camaro SS CK sockets? I put my meter on it and it had 3 ground points so I am a little confused???? Are there any CK sockets on the car?
Old Mar 2, 2016 | 09:57 PM
Majestic9C1's Avatar
they are standard sockets.. not the CK type
Old Mar 3, 2016 | 08:16 AM
WhiteBird00's Avatar
Ungrounded Moderator
That's correct... all 3157 sockets (front and back) are standard not CK.
It is not necessary to test a socket to determine the type. As you've seen, sometimes a contact will register as ground when not actively in use. You can see the difference just by looking into the socket at the contacts. 3157 sockets have four contacts - one for the bright filament power (turn signal, brake, DRL, etc.), one for the dim filament power (parking/running lights), and two for ground. The ground contacts are connected together so that they share a single wire.
When looking into the socket, a standard socket will have the connected contacts at one end on opposite sides of the slot while a CK socket will have the connected contacts adjacent to each other along one side of the slot.
