Weird electrical behavior with firebird tail light bulbs?
I pulled all of my old tail lights starting from the passenger outer most 194 across to the driver side 194. When all I had plugged in was the driver's side 194 bulb I noticed the bulb was very dimly lit, even though the car was off. When I unplugged that bulb the interior door chime went off (the door was open, but nothing in was in the ignition). If I plug it back the chime turns off. When I plugged the other 194 bulb back in on the passenger side the chime also stopped and the driver bulb turned off. Leave only one bulb plugged in and it lights up dim again. Remove them both and the door chime goes off.
Summary: Both 194 bulbs in turns them both off and no door chime.
Both 194 bulbs removed and the door chimes.
One 194 bulb in and it lights up dimly with no door chime.
Is this normal? With all of the bulbs in everything seems to act normal but it still weirds me out. I had a problem last year with my battery dying and I just chocked it up to a worn out 9 year old battery.
Do you have any aftermarket lighting inside? Or outside? Fog lights? Gauge cluster upgrades? I have also seen people make mistakes with the illumination wires behind the radio. If you're using an aftermarket radio harness, these would be the orange wires. Could be orange, orange with white, or orange with black. I would make sure these aren't connected to anything before moving forward...
Not sure where door wires would interfere with the parking light circuit. Something in the car that is tied to both circuits is probably causing the problem. Any LED upgrades in the car?
I just remembered that I do have the autotrix passenger door window fix kit installed. That's the only wire related thing I can think of that has been jacked with on the car.
Then again, this may not be a problem. Try getting all of the bulbs in place, and then test your amp draw off of the battery. I'm wondering if the door chime module has a requirement for the ground through the bulbs. Not exactly sure how their system works, but if it's looking to see a ground on the wiring for the bulbs that are not illuminated, this wouldn't be impossible.
I say make sure that you have a problem first.
