Corvette Style Cluster Needles Sweep?
Old Jul 30, 2016 | 12:39 PM
Luckyzach's Avatar
Default Corvette Style Cluster Needles Sweep?
I was wondering how easy or complicated it would be to make the gauge needles in my 2002 Pontiac Trans Am to do like they do in a corvette when you start it up. I was always raised around corvettes but I was unable to afford a corvette so I obviously settled for the next best thing. Anyways, I always thought that the sweeping needles when you start a corvette up was awesome! And I'm kinda wanting to do that in my cluster, depending on how difficult it would be. If it's extremely complicated, I probably won't do it but if it's fairly easy, I might tackle it soon.
Old Aug 3, 2016 | 12:21 AM
Daniel Richards's Avatar
well if you have a battery thats about to go out you'll get the needle sweep, needle sweep is actually a warning of the battery going out on 4th gen f-bodies. typically firs becomes noticeable after the car sits over night. so you might want to mess with it.
Old Aug 3, 2016 | 10:15 AM
Luckyzach's Avatar
Hmm, alright. I've never had it do that so I had no idea. Probably won't mess with it then.
Old Aug 3, 2016 | 01:17 PM
Atrus_SS's Avatar
It's a BCM thing, I don't think it's that easy to do. it's not just the 'vettes that do it. My wife's previous '05 G6 did it, my '14 Sierra does it.
Old Aug 3, 2016 | 06:01 PM
LT4vert's Avatar
Without being able to program the BCM, you would need to design and program a circuit that would that would feed the gauges the proper voltage to sweep the full range and back down. Then with the 99-02's the oil pressure is the only analog input, the rest is class 2 serial data. Its a cool feature but way way too much work for little gain.
Old Aug 3, 2016 | 07:52 PM
Luckyzach's Avatar
Yeah, it sounds like way too much work. I was just curious. Like I said, I would only do it if it was a simple mod but it's way out of my league and seems kinda wasteful for such a little thing. I can live without it, just trying to compete with my dad, he has an 2008 Corvette, lol.
Old Aug 4, 2016 | 06:54 AM
WhiteBird00's Avatar
Ungrounded Moderator
The BCM on 4th generation f-bodies has nothing to do with the instrument cluster other than managing a few of the warning lights (seat belt, security, etc.). So even if the BCM was programmable, you couldn't affect the gauge needles with it.
Old Aug 4, 2016 | 10:59 AM
LT4vert's Avatar
On the 99-02's all but the oil pressure and speedo are class 2 serial data though. But your are right, I did wrongly mention the BCM.
Old Aug 4, 2016 | 11:20 AM
Yes, that's correct... that data comes from the PCM not the BCM.
