What a mess
Old Dec 1, 2016 | 01:45 AM
morice68's Avatar
Default What a mess
Have a 2000 trans am. Turn signals were blinking erratically, now not at all. Hazards still working. Changed turn signal switch on the advice of an ase certified mechanic. Still no turn signals, hazards still working. I need help.. Lol
Old Dec 1, 2016 | 03:07 AM
ElkySS's Avatar
Sounds like a bad flasher
Old Dec 1, 2016 | 07:35 AM
wssix99's Avatar
Save the manuals!
1) They should loose their certification.
2) If you paid someone else to change your switch, you should kick them in the nuts and request your money back.
Folks to pay top dollar for electrical work on cars, but this is electrical 101 stuff... Our turn signals are nothing special and have a design common to most cars built in the mid-to-late 1900's and in to the 2000's. Maybe this was a BMW mechanic???
ElkySS has the answer. It's a 5 minute, $5 fix.
Old Dec 1, 2016 | 10:23 AM
TheUrbz's Avatar
Elky is correct, and i enjoy wssix's violent tendencies.
i had the same problem with my right front blinker. hazards would work but not the signal. so i got a new blinker (light hub/ blinker hub) from autobone after they asked me if firebird was made by ford and if it was 2 door or 4 door, spliced it in and still wouldnt work.....
it was a universal after all so i had to modify the bulb that fit into it (sanding down part of the plastic with a jewelers file). it would work for awhile but act up so my final fix was basically packing it full of dielectric grease. hasnt failed since.
Old Dec 1, 2016 | 10:41 AM
wssix99's Avatar
Save the manuals!
I don't think I have violent "tendencies" nor do I generally condone kicking another person in the man-region. However, in my copy of the Man Manual, such an action is permissible for gross incompetence or when someone takes you for a ride and charges you for an unnecessary and expensive car repair...
Old Dec 1, 2016 | 05:00 PM
morice68's Avatar
Default I'm not opposed to violence
Thank you for the response and information. I originally bought a flasher and was told by several mechanically inclined people that I was wrong. So 6 hours of work, being late for work, and pissed off. Now I go back to the $12 part and 15 minutes of work. People wonder why I'm medicated.. Lol
Old Dec 1, 2016 | 05:20 PM
wssix99's Avatar
Save the manuals!
What a mess.
You can be confident in knowing that you were right!
As to not confuse in your medicated state... watch out - there are two flashers. One for the hazards and one for the turn signals. The hazards are on the left side of the steering column and the turn signals are on the right side, under the lip of the bottom of the dash.
(People with this problem have driven themselves mad/off a cliff when they accidentally change the wrong flasher!)
Old Dec 1, 2016 | 05:38 PM
morice68's Avatar
Originally Posted by wssix99
What a mess.
Yup.. Got it covered bro. A big thanks to everyone for the help
