AUDIO GUYS, I have a question
Your other option is to connect the voice coils in series creating a 4-ohm SVC sub. That gets the most out of the speaker but the increased impedance to the amp will cut your power output there. Cutting the power in half doesn't cut output in half... it causes a 3dB drop in output which is about one click of the volume ****. The amp can easily handle the higher impedance but it could not handle the 1-ohm impedance that would result if you were to wire the voice coils in parallel instead of series.
