Those whith subthump t-top box.....
Is there room for this amp http://www.mtxaudio.com/caraudio/pro...under1501D.cfm to fit underneath the box. It will have to be angled so i can still put the t-tops in.
its all good, my camaro is at the stealership cuz of 3 spun crank bearings ( warranty ).. i'm just trying to figure out what would be the best way of installing the amp
Well, here's a shot of my amp rack. This version is not t-top box compatible. But if you were to tilt the amp the other direction and leave the front couple inches clear, then it would work just fine. I have all my wiring and my cap hidden underneath the amp fyi. But something similar would work for the t-top box. And no, my amp doesn't overheat, despite being directly under the box.
![](http://www.subthump.com/images/Ampracks/RFracks2.jpg)
Here's a recent t-top box I did for a single 12. Right now it's got a type R in it. But eventually will have a brahma in it. The install's not quite finished as you can see. But the formula logo is pretty cool.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
J/K, I know what it is....nice setup by the way, although I would try to hide that amp for stealth
Originally Posted by 02Z28LS1
Type R? What, is that a ricer sub or something? ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Well i guess this thread was all for not. I've decided to go with a stealthbox instead of the t-top box. Before i didn't think i could get the brahma in there with enough air space but i checked with adire and subthump and it's all good. 1 12" Brahma + 1000 watts of clean mtx power =
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
the Millhouse box does hold 1 single 12" sub. The other good choices are the stealth boxes on the sides. The other t-top boxes look like you will scratch up your t-tops..jmo.. good luck
