Electronic/radio problem
Old Feb 25, 2017 | 11:41 PM
Canuck's Avatar
Default Electronic/radio problem
After replacing the bulbs in my monsoon radio and putting it back in: the dash cluster, radio, fog and asr lights all went out. I changed a possibly blown fuse and the dash cluster worked but the others stayed out. Ater I start it and put the headlights on the blue radio time/station display goes out. If the headlights are turned off the blue numeric display goes on. The rest of the radio lights do not work as the fog/asr lights continue to stay out. While the bulbs dont work everything does function-radio, asr, and fog. Please help.
Old Feb 26, 2017 | 01:01 AM
alfablue's Avatar
This is gonna sound silly, but check your dimmer. It sounds like it got turned down.
Old Feb 26, 2017 | 06:05 AM
Canuck's Avatar
I did and wasnt the problem. thanks though
Old Feb 27, 2017 | 08:30 AM
WhiteBird00's Avatar
Ungrounded Moderator
Which fuse did you check? There are two fuses related to the instrument panel lights - the TAIL LPS fuse and the IP DIMMER fuse.
Replace those two fuses, unplug your radio and see if everything works. If so then something is wrong in the radio. Check for shorts to ground around the bulbs you installed. Note that if you replaced the factory bulbs with LEDs but didn't install resistors, that is the same as a short to ground.
