New Body Control Module
Old Apr 8, 2017 | 12:29 PM
Volcente's Avatar
Perfect!
Many Many thanks to you all!
Now I can buy the #09353691 BCM and the remotes.
Thanks!
Old Apr 8, 2017 | 04:15 PM
wssix99's Avatar
Save the manuals!
Originally Posted by Volcente
Now inside my CAMARO there is 09353681 bcm,this is the original bcm, and I want to put a REMAN BCM 09353691 that support remotes and have anti-theft.
I want to know if it works if i dont use the anti theft... i dont have shock sensor for example.
I'm moving this thread to the Stereo and Electronics section as we have additional BCM experts, who I expect can answer this more directly, who post more regularly in that section.
Old Apr 8, 2017 | 04:18 PM
wssix99's Avatar
Save the manuals!
Perfect!
Thanks!
I would think the above posts would be correct because we have people who unplug the security sensors all the time without issues, when the sensors go bad.
Old Apr 8, 2017 | 04:21 PM
wssix99's Avatar
Save the manuals!
Originally Posted by wssix99
I have to think that this is a very expensive part to buy in Italy!!!
Have you considered doing the free fix for this problem? Have you looked at the FAQ section and read the threads about the BCM fix? It sounds like you may have the common problem with the solder:
How to fix your radio/door locks/windows etc from flickering, cutting in/out
(Also Known As: BCM FIX)
https://ls1tech.com/forums/general-m...blems-fix.html
https://ls1tech.com/forums/stereo-el...lickering.html
(Pic of affected solder in Post #22 of second thread.)
Maybe 450€.
But the question is another if someone of you have try to change the bcm and use the remote without have the theft deterrent/alarm system.
The module is also expensive here in the United States. I can't remember the last time I heard of someone replacing the module and not performing the free fix I posted above.
The cracked solder issue that causes this problem is common to many different types of cars and will also occur in the stock radio, eventually. (When the radio solder cracks, the display will have problems.)
Old May 2, 2017 | 01:28 PM
Volcente's Avatar
New BCM is inside.
No problem to set the VATS of my ignition key.
Works perfect.
The remotes works perfect without the alarm.
Many, many, many thanks to you all!
Ciao Belli!
Old Jul 31, 2019 | 03:28 PM
chad cunningham's Avatar
If you don’t mind me asking where did you purchase your new bcm??
Old Jul 31, 2019 | 03:57 PM
Volcente's Avatar
Rockauto.com
Old Jul 31, 2019 | 04:15 PM
I’ve looked and they are now unavailable
Old Jul 31, 2019 | 04:25 PM
Volcente's Avatar
I've see it now.
I am sure that the bcm on Rockauto are VAT virgin so you program your vats code at fist start.
You can send a message on rock or search it on e bay but you have to search a BCM with no vat code programmed inside.
Old Jul 31, 2019 | 04:49 PM
Idk then. I can find my module on there but they are “out of stock” and won’t return to their stock. In other words “unavailable
