Weird headlight issue.. ??? .. Wtf? (VID)
Vid of issue below...
-Have the fog lights always worked with the high beams? If so did you jump the wires?
-I see a red light on the left of the dash above the fuse box, have you installed anything lately?
-Fix any DRL issues or headlight motors?
Just trying to narrow it down.
I've been chasing the problem down for years and was only able to solve it after re-pinning the connectors with tighter cable seals.
Then the thread goes off the cliff with discussion on gears...
Post #52 has the verdict with cable seals:
Grey (stock) - horrible
Green (proper) - good/no issues
Tan (really tight) - looks OK, hard to work with, time will tell if they will hold up like the green ones
The parts to rebuild the connectors are inexpensive and can all be had from Mouser. The tools are not. The tools include a special crimper and terminal removal tool, which can run $100-$400, depending on new/used, the source, and the deal one gets.
Ok... So the problem ended up being the pins in the headlight connector. My buddy came over and took a look at it, we cleaned the pins and after a closer inspection we discovered that the pins pushed back in the connector when plugged up. So he pushed the pins forward from the rear of the connector where the wires are. Something that small was the culprit of this whose bullshit. ... So I'll keep an eye on it. I'll most likely just buy a new connector and solder it in when I have some free time.
