Power Antenna Replacement Rubber bezel
Old Jan 15, 2018 | 03:09 AM
Deniz A's Avatar
Default Power Antenna Replacement Rubber bezel
Hi everyone.I am about to change my power antenna and the Rubber bezel on car body does the oem power antenna comes with that bezel or not? Where can i find that Rubber bezel can someone help? We dont have any auto part shops sell the original rubber bezel.Any help would be appreciatted.
Regards
Old Jan 15, 2018 | 04:35 AM
klinznilk's Avatar
My new one did NOT come with the rubber bezel. I may have a replacement one sitting in my garage on my backup antenna. Let me check when i am home.
Old Jan 15, 2018 | 04:39 AM
Deniz A's Avatar
Thanks m8
Old Jan 15, 2018 | 07:26 AM
WhiteBird00's Avatar
Ungrounded Moderator
The GM part number is 10298264 but it has been discontinued and appears to be unavailable from the usual online sources.
Old Jan 15, 2018 | 09:28 AM
klinznilk's Avatar
Sorry man my backup one does not have it either. Best of luck in search
Old Jan 17, 2018 | 11:27 AM
Deniz A's Avatar
Where can i find that rubber bezel can someone help me wtih that?
Regards
Old Jan 17, 2018 | 11:51 AM
Have you tried a junk yard? There should be plenty of f-bodies there.
Old Jan 17, 2018 | 11:18 PM
sjsingle1's Avatar
if you need and get a oem replacement motor and mast it comes with a nut top bezel....no need for the rubber piece anymore ....jus sayin
Old Jan 18, 2018 | 03:22 AM
Deniz A's Avatar
Seems like the power antenna part number is(ACDELCO 19245455). Does that come with anything else extra(bezel or another stuff)
We dont have much F bodies here in Turkey.
Old Jan 18, 2018 | 09:08 PM
sjsingle1's Avatar
the p/n for a new motor and mast is 10269280 .....comes with the new nut top bezel.....the motor bracket it comes with will not fit F bods.....swap out the bracket from your old motor....they no longer make the mast in black....this one has a chrome mast.....and you will need the special tool to tighten the bezel nut
Old Mar 2, 2018 | 05:44 PM
Deniz A's Avatar
Thanks a lot i did what you said that looked much better than the 2nd design
Old Apr 9, 2018 | 04:05 AM
AiDRocks's Avatar
I have an extra antenna with that piece. The motor isn't working anymore. PM me if interested.
Old Apr 9, 2018 | 04:12 AM
AiDRocks's Avatar
It will be cheao BTW
