2002 le 35th stereo replacement
I have read Whitebird FQ but did not see what i would know to be the answer to my ? The antenna adapter I spoke of was also connected to a small tin box that appears to go to the trunk area. anyone have any thoughts on this ?
Last edited by WhiteBird00; Apr 20, 2018 at 06:57 AM. Reason: Merge consecutive posts
The only wires going to the optional CD changer are in the separate 9-pin flat connector plugged in at the back corner of the head unit and there are no orange or yellow wires there. There are orange and yellow wires next to each other in the black half of the main head unit connector. They carry battery and ignition-switched power respectively. It sounds like someone tapped into them to power some accessory - you'd have to trace the wires to find out what that was.
The pass window needs a new window motor. There is a bi-metal strip in the motor that cuts it off normally when it gets full up or down. That gets old and starts to open the circuit with less load until it does it trying to get the window up.
