Front cam on fbody camaro
Old Apr 4, 2018 | 05:48 PM
99 ss's Avatar
Default Front cam on fbody camaro
is there anyone that put a front camera to there fbody ? I was thinking of doing it to mine but wanting to know if you guys did where did you mount it at ? With out drilling any holes if that’s the only way then I’m not doing it any help would appreciate thanks
Old Apr 5, 2018 | 08:32 PM
VIP1's Avatar
Copy & Paste Moderator
Suction cup mount to windshield to right of rear view mirror.
Old Apr 5, 2018 | 09:44 PM
Need4Camaro's Avatar
Mine came with double sided 3M tape and it has held fine... please dont drill any holes through your windshield to mount a dashcam
Old Apr 5, 2018 | 11:42 PM
99 ss's Avatar
Lol no not a dash cam . I’m wanting one to go outside of the car like the grill of lower of the car
Old Apr 6, 2018 | 12:10 PM
jaxcam02's Avatar
I think hes talking about a parking assist cam, not a dash cam lol.
If you have a billet grille it should be east peasy, with a OEM grille it might take some backyard engineering.
Old Apr 6, 2018 | 01:44 PM
bammax's Avatar
If you're in a front plate state it's as easy as getting a plate mounted back up camera and putting it on the front. If you have a smooth front then you need to get more creative.
Old Apr 6, 2018 | 04:37 PM
99 ss's Avatar
Hay guys no I don’t have a front plate on the car I have the slp ss grill
Old Apr 7, 2018 | 05:48 PM
bammax's Avatar
With the black plastic ss/bowtie grille you won't be able to center the cam without drilling holes.
If you're willing to deal with an off center mount there's a pretty easy way to do it. Reach in the top vent in your grille (either side works) and pull the grille mounting screw. Take it to Lowes (or the hardware store of your choice) and find the exact screw but about 3/4 - 1" longer. Find a cam with a small mounting bracket that either can rotate over the cam (U shaped) or that's meant to be hung. Drill a hole in the bottom center of that mounting bracket the diameter of your screw (if it already has a hole then just make sure your screw has a head bigger than the hole or use a small washer). Now you can use the grille mounting screw to sandwich the bracket against the inside roof of the vent. Make sure you have it aimed where you want it then use some tape to outline the bracket on the vent (you'll need to pull the screw out and the tape outlines will let you realign easier on final install) . To maintain the alignment you want a small angle (L shaped) brace or a strip of metal (another Lowes run and check the hardware section). Set the vertical section of the brace behind the vent and the horizontal section over the mounting hole in the grille. Mark and drill a hole in the brace to align with that factory hole. Now you can assemble. Screw goes through the brace, then through the bracket, then through the grille and into the factory nut. Whole thing is removable with 1 screw and no holes in the factory parts. Only thing to watch for is the cam losing its position with vibration. If that happens you can play with the brace to grab the back of the vent better, and if it still doesn't stay take the bracket off and drill a little hole through the bracket and brace and use a pop rivet to lock them together. That will stop them from moving side to side and a rivet will press up against the plastic grille without needing a hole like a screw would.
Old Apr 23, 2018 | 07:47 PM
toplessHO's Avatar
Ive been using cameras that only need about 1/2" hole
and for about $12 each they put the $40K caddy one to shame
